6 members (55shaker, Hotrod Lincoln, Peggy M, 2-Ton, Hambone, Goach2), 227 guests, and 4 robots.
Topics128,258
Posts1,058,014
Members48,479
#806568 12/14/2011 3:42 AM
1951 Chevy 3100 with 235 swap
Any advice on an over the counter Alternator, part numbers or year and model number of car Alternator that will work ? I can fab a bracket. just looking for something I can go to a parts store and ask for.
H Online: Content
I assume the truck has been converted to 12 volts already? I'm not aware of any 6-volt alternators other than some very spendy custom-built ones. If the system is 12 volt already, the simplest alternator conversion is the Delco 10-SI type which was used as original equipment on everything GM produced from the late 1970's through the mid-1990's. Try looking for an alternator for any Chevrolet 350 from 1976 to 1983 or so. From 85 on up, some GM alternators had metric threads and pulleys for serpentine drive belts.
