| | | Forums66 Topics128,126 Posts1,056,351 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | Will the wheel hubs and drums from a 1959 GMC 1-ton work on a 1959 Chevy 1-ton? Converting from single to dual wheels and have found a possible donor set of hubs from a GMC.
My first guess is yes, but wanted to check with the experts.
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | You may want to ask this in the "Big Bolt" sub-forum. Big truck guys are there.
Only a suggestion, good luck, someone on this list should know the answer to your question, I wish I did, but I don't, just mess with 1/2 ton trucks...
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'll put you in the 1-ton forum first and see what you get there. | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | They are the same from 53 through 59 in 1-tons for Chevy and GMC.
P/N 3683818 fits both 3/4 and 1 ton w/duals.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
