7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,722 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80651 07/31/2007 12:40 AM | Joined: Jun 2005 Posts: 18 New Guy | | New Guy Joined: Jun 2005 Posts: 18 | I am currently converting my '49 half-ton from a splash oiled 235 to a full pressure 235. I know if converting from a 216, you need to reuse the bellhousing, clutch, pressure plate and flywheel. Since I'm going from an early 235 to a later model, does anyone know if you can keep the clutch, pp and flywheel from the full pressure 235 and simply swap the bellhousing? | | |
