3 members (Otto Skorzeny, J Lucas, Steelonsteel), 95 guests, and 1 robot.
Topics128,211
Posts1,057,471
Members48,473
I'm sure this has been discussed but I searched and couldn't find. I was told a TF 1/2 ton rear axle and driveline could be swapped into an AD 1/2 ton ('53) by reversing the springs with some shackle modifications. This apparently moves the rear wheels back about 2" which more or less centers them in the fender openings.
Does anyone have any experience with this?
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
It could probably be done that way but...
You'd be better off in the long run to buy new spring perches, set the pinion angle to match the driveline angle and weld the new perches on.
Thanks Cletis, I haven't attempted this before so I need all the advice I can get.
Allan
1951 GMC 1/2-ton
I dint use a TF rear end in my 51 swap but I did reverse the springs to move the center bolt further back in the wheel well
Magfarm51 - I'm considering doing the same thing. Putting a '57 TF rear end in my '53 to replace the enclosed driveshaft. I think the biggest hurdle will be getting new axle seats and putting in new u bolts etc. CPP (Classic Performance Parts) has a kit ~ $75 that says it's a flip kit for the TF trucks but will work to put TF axle in AD truck.
'53 Chevy Pickup, 235ci, 4 spd Saginaw, Fenton Headers, 2x1 Offy Intake, Monoleafs dropped front springs, 15" rally wheels
might not be what you would be happy with,but i used a rear end from a 1972 haft ton 3.38 gears i was told,but the sucker bolts right in.btw i help remove it from the donner.
Heathlce and John, those are great suggestions, I'll be looking into all of them when the time comes. Thanks.
Allan
1951 GMC 1/2-ton
John, can you explain what you did about the transmission and drive shaft?
DG
Denny G
Sandwich, IL
John. Are you saying the 72 rear just bolted onto your AD springs? Or you used the 72 rear and springs and they bolted onto your shackles and front hanger?
Dennis
yes it did just thati am useing 250 6cyl with 700r4 auto.had new drive line made.
