2 members (Danielbolt, Steelonsteel), 82 guests, and 3 robots.
Topics128,095
Posts1,056,492
Members48,444
#797274 11/12/2011 4:55 PM
Ok Im running a carter yf 788SA and I want to start gathering the parts to some day do the dual carb set up. I will look for the exact same carb but If I cant find it will any other carb go well with it in the carter family. I could always just get 2 matching carbs. Thanks Stovebolters.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
You must use two matched carbs.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Cool. Well I found a matching carb so Ill pick it up.
My YouTube:
Wow, that was fast! I assume the tag numbers on the carbs match?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
well no But there both yf 788, one is 788s and the 0ther is 788sa so I figure I can make that work.
My YouTube:
ok so question. If both carbs are a size 3 will they work or should number mach for sure?
756S size 2 auto choke (1937 and newer Chevy engines)
787S size 2 manual choke (1937 and newer Chevy engines)
788S size 3 manual choke (1950 and newer Chevy engines)
789S size 3 auto choke (1950 and newer Chevy engines)
964S size 2 manual choke (1937 and newer Chevy engines)
965S size 2 auto choke (1937 and newer Chevy engines)
966S size 3 manual choke (1950 and newer Chevy engines)
967S size 3 auto choke (1950 and newer Chevy engines)
2008S size 2 manual choke (1937 and newer FLEET economy engines ONLY)
2046S size 2 manual choke (1932 � 1936 Chevy engines ONLY)
2100S size 3 manual choke (1950 and newer Chevy engines)
2101S size 3 manual choke (1950 and newer Chevy engines)
My YouTube:
Carburetion specialist
From my website:
"Carter numbering systems. Three different types of numbering systems are found on Carter produced carburetors.
(1) On carburetors built for Chrysler Corporation, a series of 3, 4, or 5 letters and numbers; i.e. EV1 or D6H2.
(2) On carburetors built for Ford Motor Company, the “Ford” numbering system which is “lnll – l(l)(l)” or letter, number, letter, letter dash letter (possible letter) (possible letter) i.e C5VF-A. This system is codified in that the first letter is the decade (B=1950’s, C=1960’s, etc.); the number is the last digit in the year; the 3rd and 4th letters (before the dash) represent the vehicle model (VF=Lincoln); and the letter or letters after the dash are a modifier which distinguishes the exact application. Thus in the example C5VF-A, the carburetor would have been the first application for Lincoln in the year 1965.
(3) The traditional Carter numbering system which consisted of 1, 2, 3, or 4 digits; followed by the letter “S”, possibly followed by another letter. It is extremely doubtful that any of the single, double, or early triple digit tags will appear; as they were produced before 1930 and were constructed of red cardboard. The metal tag appeared about 1930 with tag numbers of about 300s. The 4 digit tag appeared in 1952, and was continued on until the end. The letter S and following letters, when present, have caused much speculation (mostly incorrect). In Carter’s terminology, an individual part such as an idle mixture screw was a single part; whereas two or more individual parts sold together such as a needle, seat, and gasket were sold as an “assembly”. Carter used the suffix letter S to denote assembly. Since all carburetors are composed of multiple parts, the letter S was appended to all carburetors using the traditional numbering system i.e. 938s. If a significant engineering change was made to the carburetor, the letter “A” would be appended to the S (i.e. 938sa). A second change would have the letter A replaced by the letter B (i.,e. 938sb). The highest engineering change of which I am aware is 4 i.e.938sd. Contrary to popular belief, the S DID NOT mean standard transmission, nor the SA automatic transmission."
Jon.
The Carburetor Shop
