| | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | After driving for the 1 st time in 28 years I have a stalling out problem at stop signs... I have enough idle speed and does not appear to have lack of fuel to the carb, the fuel filter shows 3/4 full when I checked it... I have new fuel tank, clean fuel pump and fuel filter... It was running at a nice engine temp, although when I got back home and idled for a few minutes it did get a bit warmer and was hard starting...
I am running a 58-60 235 W/Rochester carb that was rebuilt last year and has been running good and a 54 Hydra-Matic transmission...
Thanks in advance for the help...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Bummer! When it stalls, is it done for the day or does it start right back up?
You said you "have enough idle speed" - just FYI, the '59 shop manual shows 425 - 450 rpm with the auto trans in Drive.
Good luck, hope you get this issue solved soon.
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | waldo53 when it stalls out it does start but not right up like it does when its cold... Have idle set at 450 rpm... Checking other things today to see what might be causing the issue...
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Adjusted the points ( Dwell is 36 )... Heat riser was not closing properly, fixed it... Only stalled once today in about 15 miles of driving at a stop sign... Still did not start right back up but better then the other day... The shop manual says to hold the throttle down half way when starting a warm or hot engine, will try this next trip...
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | When warm, does the starter grunt while trying to crank it? | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Roy Rodgers,
Starter turns fine... I fixed that problem long time ago... Good ground cables and engine timing solved that one...
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Is the by pass wire from the starter to the coil intact so that while cranking the coil gets full battery voltage? Is the spark a bright blue or orange? Sometimes a coil can get hot and break down. | | |
