5 members (rfs56trk, 55shaker, DadsFirstPickup, JoergK., 1 invisible), 324 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
Would like to know if anyone knows if I can remove the old flooring from the rear of Sub without lifting body off frame. Only cuz I have no room to remove body off frame. Im renting a storage to restore my 63 Sub. Thanks
no way, not easily. everything bolts to it! why do you want to?
Cuz I see alot of the 3/4" plywood starting to crack and I would just like to replace the flooring as well. Im not in a Big hurry I guess I can wait for just a while longer. Thanks for your reply anyways
it can be a chore esp if there is any rust problems at all around the edges
ron
it holds the bottom dimension of the whole back of the truck. its actually about 1" thick. theres a seam tongue and grove down the middle. if its just the rubber cracking carpet it! or scrape off the rubber and find vinyl flooring that matches. take pics for us so we can see the cracking.
