2 members (carbking, RLB),
157
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | I have came across a short 5'3" truck bed recently. The floor is corragated metal. The stake pockets are merely holes in the top of the bed sides with 2 brackets on the outside of the bed side. The bed sides go up then break at a 45 degree angle. Instead of a roll it is squared off. Is this a manufactured bed or something a very good metal worker has made?
Pictures can be seen on the Kansas City Craiglist site item 2746572513
Thanks, Ernie
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | Maybe, the brackets on the outside of the box to hold the "stakes" made me thing it was intended for use. Thanks for your reply. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I can think of 2 things it might be. 1 would be a conversion bed for an early roadster to make it into a pickup, either factory or aftermaket. The other (this is the one I really think it is) would be a bed from a military (specifically Navy) spec '40-'42 Willys Americar Truck. I have been told that Willys built some of their trucks with a shortened bed to spec for use on bases.
Bill Burmeister | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | Interesting idea, I will google that. Thanks | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | I am thinking it ia a military bed from WWII or Korea. Doesn't match any cilvian bed I can find. | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | My research inticates it is an early 30's dodge or Fargo bed. Thanks for your help. | | |
