4 members (Ricks Big Dump, Donf, Peggy M, 1 invisible), 148 guests, and 3 robots.
Topics128,086
Posts1,056,101
Members48,434
#805536 12/10/2011 10:12 PM
Custom Title
Custom Title
Has anyone ever tried putting Stromberg 97's on an Offy 2x1 on a 235? I know the Strombergs have a 3 hole mount and the Offy is a 2 hole. Is there an adapter available for this? I don't know if this is even worth attempting, but Strombergs seems so cool and period correct.
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
I'm running dual 97s on a Edmunds manifold so don't need an adapter. But I did see them at secretsofspeed.com. The hardest part was making up the linkage. I like the look and have been very happy with them.
40 Chevy 1/2 ton
...and expensive.
If you can find original-equipment Strombergs they'll probably work OK, but stay away from the repops. Like a lot of the reproduction stuff, I've heard some pretty bad comments about the new ones that are on the market now. Like any dual-carb setup, there's a distinct possibility you'll be over-carbureted in the low speed and midrange area.
I had a friend back in high school who installed a dual-carb manifold on a 216 and adapted 2 Strombergs to it. After several carburetor fires that blistered the paint on his hood and almost burned the car down, he went back to a single Carter 1-barrel.
I have a friend on another board that because he's into F@%& flatheads he prefers a Stromberg on his 235 bolt. He says (and I'm just repeating this as I have no experience with these) that he prefers the "94's". He has one on his 235 using .050 jets and a 7.5 power valve that performs perfectly and delivers 20 mpg.
His favorite for duals is the Holley/Chandler Grove "94's" used on the early '40's flatheads.
I pass this along for whatever it's worth.
