| | | Forums66 Topics128,089 Posts1,056,116 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | Has anyone ever tried putting Stromberg 97's on an Offy 2x1 on a 235? I know the Strombergs have a 3 hole mount and the Offy is a 2 hole. Is there an adapter available for this? I don't know if this is even worth attempting, but Strombergs seems so cool and period correct.
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I'm running dual 97s on a Edmunds manifold so don't need an adapter. But I did see them at secretsofspeed.com. The hardest part was making up the linkage. I like the look and have been very happy with them.
40 Chevy 1/2 ton
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Feb 2004 Posts: 29,796 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,796 | If you can find original-equipment Strombergs they'll probably work OK, but stay away from the repops. Like a lot of the reproduction stuff, I've heard some pretty bad comments about the new ones that are on the market now. Like any dual-carb setup, there's a distinct possibility you'll be over-carbureted in the low speed and midrange area.
I had a friend back in high school who installed a dual-carb manifold on a 216 and adapted 2 Strombergs to it. After several carburetor fires that blistered the paint on his hood and almost burned the car down, he went back to a single Carter 1-barrel. Jerry
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I have a friend on another board that because he's into F@%& flatheads he prefers a Stromberg on his 235 bolt. He says (and I'm just repeating this as I have no experience with these) that he prefers the "94's". He has one on his 235 using .050 jets and a 7.5 power valve that performs perfectly and delivers 20 mpg.
His favorite for duals is the Holley/Chandler Grove "94's" used on the early '40's flatheads.
I pass this along for whatever it's worth. | | |
