| | | Forums66 Topics128,180 Posts1,057,150 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 104 | My '52 6400 has a newer 250 in it. The bellhousing ears for the rear mounts are angled and the crossmember looks like the original 235 housing lay flat on it. How are you swappers bolting these bellhousings down ? Mine has a bunch of cobbled junk that has the transmission sitting almost 2 inches too high. Do I need a different housing ?
1952 Chevrolet 6400 flat bed
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Read some years back about using the 54 crossmember in the older trucks to mount the later engines and trans slanted mounts. | | | | | Joined: Nov 2011 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 104 | Read some years back about using the 54 crossmember in the older trucks to mount the later engines and trans slanted mounts. That would be an easy enough swap if that's all it needed....thanks !
