7 members (Phak1, moparguy, Chooglin, 54farmtruck, 2-Ton, GMCJammer51, WICruiser),
47
Mod | | | Forums66 Topics128,151 Posts1,057,004 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 15 New Guy | | New Guy Joined: Nov 2011 Posts: 15 | Would like to know if anyone knows if I can remove the old flooring from the rear of Sub without lifting body off frame. Only cuz I have no room to remove body off frame. Im renting a storage to restore my 63 Sub. Thanks | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | no way, not easily. everything bolts to it! why do you want to? | | | | | Joined: Nov 2011 Posts: 15 New Guy | | New Guy Joined: Nov 2011 Posts: 15 | Cuz I see alot of the 3/4" plywood starting to crack and I would just like to replace the flooring as well. Im not in a Big hurry I guess I can wait for just a while longer. Thanks for your reply anyways | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | it can be a chore esp if there is any rust problems at all around the edges ron | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | it holds the bottom dimension of the whole back of the truck. its actually about 1" thick. theres a seam tongue and grove down the middle. if its just the rubber cracking carpet it! or scrape off the rubber and find vinyl flooring that matches. take pics for us so we can see the cracking. | | |
