5 members (Peggy M, Hotrod Lincoln, Gdads51, mick53, 2-Ton), 132 guests, and 4 robots.
Topics128,165
Posts1,056,989
Members48,458
#805367 12/10/2011 4:27 AM
hi i have a chrome earlys 50s front axle will that fit under my 37 or will it be too wide?
1937 1/2 ton
No. It is a direct bolt in and infact is a path to do other things. It is a heavier axle with a larger king pin. It will also allow you to use 49 to 54 car backing plates and break drums giving you a five bolt 4-3/4" spacing, if you decide to go to an open drive line, with a 4-3/4" rear axle bolt patern. It will also give you Bendix brakes instead of huck brakes. It is great upgrade for your truck.
thanks smile thats the info i needed
1937 1/2 ton
what about the ride hight will the 50 truck axle be the same as the 37 or higher or lower
1937 1/2 ton
It will be the same. Everything is the same, you just got what amounts to a heavy duty axle compared to the 37 axle. Definitely a "good thing"!
