0 members (),
256
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | hi i have a chrome earlys 50s front axle will that fit under my 37 or will it be too wide?
1937 1/2 ton
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | No. It is a direct bolt in and infact is a path to do other things. It is a heavier axle with a larger king pin. It will also allow you to use 49 to 54 car backing plates and break drums giving you a five bolt 4-3/4" spacing, if you decide to go to an open drive line, with a 4-3/4" rear axle bolt patern. It will also give you Bendix brakes instead of huck brakes. It is great upgrade for your truck.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | thanks  thats the info i needed
1937 1/2 ton
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | what about the ride hight will the 50 truck axle be the same as the 37 or higher or lower
1937 1/2 ton
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | It will be the same. Everything is the same, you just got what amounts to a heavy duty axle compared to the 37 axle. Definitely a "good thing"!
