9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop),
105
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 104 | My '52 6400 came with a flat on the inside dual and I need that tire to line up with the trailer ramp for loading/unloading. I removed it from the truck and broke it down. Good thing I had the owners manual to tell me where to find the pry slot in the ring. I've worked on plenty of 3 piece wheels in the old days but never a 2 piece, so this was new for me. I suspected it may be a bad core but as I was pounding the bead loose, lots of dust kept spewing out of the valve stem hole in the wheel. I figured it had been flat for some time and had dirt inside and I was right. I vacuumed about a pound of dirt out of the tire after I got it apart. I checked the tube for any leaks but only the core leaked, so I replaced that and put 'er back together. I forgot how hard the tire guys worked on these old split wheel trucks. I also discoverd the outside wheel is the large center hole and should probably be replaced. The inner fit the hub so tight that I had to remove 3 of the axle flange bolts and washers to get it off.
1952 Chevrolet 6400 flat bed
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If the outside has a larger center hole, it comes from a later model. And it does need to be replaced because these wheels were hub piloted. The studs were not designed to pilot the wheel. | | |
