2 members (VicZ, doyle1950), 143 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
#805084 12/09/2011 6:44 AM
Just wondering how some of you work with thinner pitted metal The fenders on my 46 are in good shape except for a couple rough patches around the headlights. I'm afraid to grind down too deep.
Want to see how you pros do it
Thanks in advance
Ken
1946 Chevrolet 2-Ton
More pix of the '46 on Photobucket
1954 Chev 1/2-ton
3 Farmalls
4 John Deeres
1 Oliver
1955 DeSoto Fireflite
I'm pullin for ya. We're all in this together -- Red Green
Ken,I'm no pro,but I imagine lead loading after treating the rust might be the answer.
The only other way would be to cut out the affected areas and replace them but I'm sure someone more qualified than I will chime in soon....
More pix on Flickr.
If I had a super thin area I would rather bite the bullet and cut it out than try to band aid it. I think you will sleep better at night knowing it was done right. Just my opinion.
Ex Hall Monitor
Ex Hall Monitor
Agreed.
Tiny #805281 12/09/2011 11:33 PM
Custom Title
Custom Title
If it's lightly pitted, soda blast it to bare steel, then start applying high build primer. Sand the surface back down between coats. This will reveal the high/low spots. Keep priming and sanding until the surface is flat and smooth again. A thin coat of body filler can speed up this process before the high build. If the spot is really bad, it's better to cut it out and weld in new steel.
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
Lead is the best....since we learned "how to" from an old timer I will never use bondo filler again, well maybe in just a few cases. Try to learn to used lead, you'll be surprized how easy it is!
....David
thanks foe help guys
Ken
1954 Chev 1/2-ton
3 Farmalls
4 John Deeres
1 Oliver
Soda blasting will only remove paint, it is not aggresive enough to clean rust scale out of the pits.
Two options:
You'll need a sandblasting media more aggressive to insure all the rust scale is gone. Then check to insure the metal is still structurally sound with an ice pick. If the pick goes through, time to weld in some new metal. If it does hold the ice pick, epoxy prime.
My preference would be to replace any pitted metal with new stuff. Metal is cheap to install before the paint goes on. Rework gets expensive.
