| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 68 | What radiator will fit my 52-3100 on top of a 82 S-10 w/V6.& automatic tran? The steering box seems to be a problem with the radiator & the bottom hose. I would like to buy a new one. But where is the best deal? This is just going to be a driver. But I want it to look good.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | This is what I have for my 51: Walker Radiator Works
~Jim
| | | | | Joined: Nov 2006 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 68 | It is a Case radiator 4 core. I hope this is going to work! Open for comments. It has a 2 3/4" cap. Witch I will change to a 15 LB.Chevy cap. Take a look in My photo-bucket and tell Me what you think. It fits good maybe I can make it work.
| | | | | Joined: Nov 2006 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 68 | I found a radiator cap today that fits! I will put it all together and try it out. It is a 7 lb pressure. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | !5 lb is good if the radiator is good.The 7sounds better if you are using old goods. | | | | | Joined: Nov 2006 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 68 | I put the case tractor radiator in and it fit and cools very good. The pic's are in my photobucket.
