0 members (),
72
7
Mod | | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 216 and a full pressure 235 have the same bolt pattern on the back of the engine, so a 1938-46 bellhousing will work in your case. My concern is if your 36 uses a standard or master transmission. If it is a standard then the 1938-46 bellhouring will not work.
1936 was the first year for hydraulic brakes.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2010 Posts: 22 New Guy | | New Guy Joined: Dec 2010 Posts: 22 | Hi Dave,
It is a 33 RPU so not sure what transmission they use. I have access to a 38 Chev truck bellhousing.
Cheers
Damian | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I was just thinking that that is most likely a right hand drive car, so you will most likely need a bellhousing from a right hand drive truck for the clutch fork and pedals to work.
