I've replaced the wood in my cab as the old wood was totally gone, so I had nothing to use as a pattern for the door hinge bolt holes. As far as I can see, I have to close the door to line the gaps up and by doing that I can't mark the wood to drill the bolt holes. Can anyone out there advise me on a proper technique to transfer the bolt pattern to the wood so I can drill the holes in the proper places and have the doors line up? Thanks to anyone that can help.
