3 members (WICruiser, Charles in CA, Otto Skorzeny), 37 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#804695 12/08/2011 4:32 AM
I have the cam out of the engine to replace a broken thrush collar. I have read that the fiber timing gears can blow apart. This one looks in excellant shape, it may even have been replaced at some time. I am wondering if it should be replaced since it is out. The oil passage has been cleaned so I know the gear will be lubricated. Should it just be replaced for safety reasons or not a worry. From what I can tell, the biggest cause for the gear to go bad is lack of lubrication.
If you never tell a lie, you never need to remember what you said.
If it doesn't break when it's pressed off to replace the thrust collar, there shouldn't be any reason you can't reuse it.
Bill Burmeister
I pressed it off and back on already when I started reading about them giving trouble. I will inspect it closer for cracks, if I find none will plan on using it. Thanks
H Online: Content
It was pretty much common practice to replace the fiber gear with an aluminum one, especially if the engine was expected to see heavy duty use like in a mid-size truck or a performance engine. They're a little noisy, but a lot more durable than a fiber gear.
In my experience fiber gears only fail when they are starved for oil. If the supply slot in the back of the timing plate and nozzle are clean so the oil is not restricted you should be fine.
My Blog
