4 members (klhansen, Hotrod Lincoln, Hush, Tronman), 71 guests, and 2 robots.
Topics128,206
Posts1,057,435
Members48,471
So I've pulled out the seatbelts in addition to the seat because they were annoying me, applied dish soap to the grommet and fuel filler neck...and STILL can't get the neck through the grommet! I'm a little perturbed.
It appears to me to be an angle-of-attack issue. Does anyone have any tips for twisting or turning the tank a certain way to push the neck through in my '69 C-10?
Darren
1969 Chevy C-10 Fleetside
V
V Offline
Soap is a good Idea. Also what about warming it up, with a hair dryer to make a little more pliable? Sometimes stuff like this works and sometimes it doesn't. Especially if the grommet is old and hardened over time. If it doesn't work, what about cutting off the original and replacing it with a new aftermarket one? Just food for thought. Hope this helps.
Ex Hall Monitor
Ex Hall Monitor
If I'm understanding the problem correctly the grommet is already in the opening and you're trying to shove the neck through it? If so try it the other way. Put the tank in place and push the grommet over it. With the grommet already in place the rolled lip at the end of the neck may simply be too big to shove through the existing space with the body metal not allowing the grommet to expand enough to allow the passage. I put the grommet on my '38 this way with no issues.
Yes, it's a new grommet. I can't imagine getting it installed with the tank in place, but I'll try!
Darren
Ex Hall Monitor
Ex Hall Monitor
Undoubtedly it's different from my '38 but it's something to try since the way you've been doing it isn't working. Good luck.
KY LIQUID...has got to WORK
1948 Chevy 5 Window 1/2 Short Bed
1969 Dodge Coronet SUPER BEE 383 Ramcharger
1949 Bentley Mark VI Standard Saloon
http://imageshack.us/photo/my-images/695/dsc04398mm.jpg/
My first question is where did you get said grommet, there is the possibility is a cheap chinese imitation, and won't fit no matter how hard you try
Got it from LMC Truck.
Darren
IIRC, the pass side of the tank must be darn near the roof to insert the neck thru the grommet on 67-72 trucks. There is a sweet spot you must hit to get it in. We used Astroglide.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I had the same problem on mine with a new grom,met. I used a lot of vocabulary.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I put both on mine on from the outside after the tank was installed. A little synthetic grease on the filler neck and a little on the body. Using a small flat blade screw driver they went right on. Then just wiped off the excess and followed up with a soap and water wash. I don't think either one took more than 5 or 6 minutes.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Ex Hall Monitor
Ex Hall Monitor
That's the way I did it on my '38 with the exception that I used silicone spray.
You said dish soap. That may be the problem. When I replaced a driveshaft carrier bushing, I intially tried a liquid dish detergent and had the same problem. When I changed to a plain old bar of hand soap it slid right in.
Harold Wilson
41 Chevy 3/4 Ton
Something you might try is silicone grease, like Syl-Glyde. That's what I used, filler neck pretty much slid right in.
You can get Syl-Glyde at Napa.
Bill Burmeister
A few days ago, I placed my new gas tank in the truck and left it unbolted so I could wiggle it as needed. I then worked on the filler neck grommet from the outside slowly and patiently. After about 15 minutes, it was done and eaier than I thought. Bolting down the aftermarket tank was another story!
Darren
