7 members (KEVINSKI, Otto Skorzeny, Tronman, Charles in CA, Goach2, 66flea, 1 invisible), 233 guests, and 3 robots.
Topics128,257
Posts1,058,015
Members48,479
#804466 12/07/2011 6:01 PM
Where can i buy them.. Thanx
sps Offline
Did you find any on it. I've had a few boxes and have never found a gasket. I'm not saying there are't any, I just don't know of any. If so someone on this sight will know. You could use Permatex gasket, I would think that would work. It's just greese in those steering boxes. I was told John Deer corn head greese is what you use in them.
On top of mine there was a thin silver one,The side was so greasy couldnt tell, but yeah little silicone prolly wouldnt hurt."STOVEBOLT" is my encylopedia on such things.lol Thanx
upon further review it has gaskets on both surfaces.
You could buy paper gasket material and cut your own.
Drew
I don't have these patterns yet on the website "the Gasket Exchange" but if someone want to scan the gasket after they make or find one, I'll put it up.
I have had success making gasket patterns by putting the part on a xerox machine, and then using the copy as a pattern.
The Gasket Exchange
Kurt
The easy way to make a gasket is to lay the proper thickness gasket material over the
surface transfer a few holes with the ball end of a ball-peen hammer. Run some bolts up
finger tight to hole it in place and then gently start tracing around the edges of the casting
with the flat end of the hammer. Easiest to do the inside first then finish with the out side.
Also helps to rough cut the sheet so your not fighting with all the waste pulling it out of
shape.
DG
Denny G
Sandwich, IL
I have also had good luck inking up the gasket surface and then pressing a piece of paper or the gasket material so as to make a "print"
My focus is always to make a pattern, which I save for the next time I or someone else needs one. I routinely scan any gaskets I buy for the same reason. Saves a lot of time in the long run.
Kurt
