| | | Forums66 Topics128,257 Posts1,058,015 Members48,479 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | Where can i buy them.. Thanx
| | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | Did you find any on it. I've had a few boxes and have never found a gasket. I'm not saying there are't any, I just don't know of any. If so someone on this sight will know. You could use Permatex gasket, I would think that would work. It's just greese in those steering boxes. I was told John Deer corn head greese is what you use in them. | | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | On top of mine there was a thin silver one,The side was so greasy couldnt tell, but yeah little silicone prolly wouldnt hurt."STOVEBOLT" is my encylopedia on such things.lol Thanx | | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | upon further review it has gaskets on both surfaces. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | You could buy paper gasket material and cut your own.
Drew
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I don't have these patterns yet on the website "the Gasket Exchange" but if someone want to scan the gasket after they make or find one, I'll put it up. I have had success making gasket patterns by putting the part on a xerox machine, and then using the copy as a pattern. The Gasket Exchange Kurt | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The easy way to make a gasket is to lay the proper thickness gasket material over the surface transfer a few holes with the ball end of a ball-peen hammer. Run some bolts up finger tight to hole it in place and then gently start tracing around the edges of the casting with the flat end of the hammer. Easiest to do the inside first then finish with the out side. Also helps to rough cut the sheet so your not fighting with all the waste pulling it out of shape.
DG
Denny G Sandwich, IL
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I have also had good luck inking up the gasket surface and then pressing a piece of paper or the gasket material so as to make a "print"
My focus is always to make a pattern, which I save for the next time I or someone else needs one. I routinely scan any gaskets I buy for the same reason. Saves a lot of time in the long run.
Kurt | | |
