3 members (KEVINSKI, MikeE, joe apple), 102 guests, and 2 robots.
Topics128,034
Posts1,055,551
#8043 11/11/2002 9:52 PM
After searching past topics, it looks like a SM420 will bolt to my 57 235 that currntly has a 3 speed that pops out of 3rd. Also looks like I'll need a longer driveline. Can someone confirm this? A fellow bolter' has offered me a 420, that was working fine when he pulled it.
57 3100 235 3 spd
#8044 11/11/2002 11:00 PM
Yes, it will bolt in. I think the driveline is the same length. The 3- speed has a tailhousing and the 4- speed doesn't.
Paint & Body Shop moderator
#8045 11/12/2002 3:45 PM
Thanks for the reply 4.
Excuse my ignorance. But if I take off the 3 speed w/ the tail housing and put in the 4 speed w/o, wouldn't there be a gap where the tail housing was. I must be missing something.
Thank you.
57 3100 235 3 spd
#8046 11/12/2002 5:04 PM
Drive shaft! I meant drive shaft! Not drive line. Sorry about that.
57 3100 235 3 spd
#8047 11/12/2002 10:07 PM
The 4 speed is longer than the 3 and takes up the space.
#8048 11/17/2002 6:10 AM
I disagree on last post. 4spd is shorter, and requires a two-pc drive shaft too. Is yours the ball end for tork tube type or the flanged type with park brake on it, or has a yoke on it? If has yoke or flange, will need a slip joint somewhere, so needs second joint for that. Even the tork tube shafts had two pcs. I think if you have tork tube with 3spd, you would need whole rear from a 4spd set-up. I would go with 4spd, change the rear to newer open line, get two pc shaft and make x-over to hold mid-joint. If you look in an assembly manual for the driveshaft from a short COE (5100model), you will see a sort-of one pc shaft with slip joint on trans end that is just like joint usually put in middle. That would be another possible method of attaching.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#8049 11/17/2002 2:51 PM
Socket Breaker
Socket Breaker
hey acme, if u click on the little icon with the piece of paper with the pen over it, u can edit your post if you goof it up.
I do it all the time with my posts...
just letting you know.
smile
-Woogeroo
