0 members (),
89
0
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Guys;
1950 3800 1-ton.
Trying to pull the steering arm off its bolts so I can pull off the brake flange plate and pound out those kingpins. Is that thing pressed on somehow? I cannot for the life of me get that thing to separate or the bolts to come out. If it wasn't so tight I'd push the pickle-fork in there but its a little too tight and don't want to break anything.
Also, does the kingpin lockpin just slide out once unbolted? Or is there another secret to getting that pin out of there? Thanks | | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | I gently knocked the bolts out with a small hammer with the nuts still on there (so it doesnt mushroom the end) until the nuts hit the arm. then i just knocked them out the rest of the way with a punch. I believe my driver side was tight like yours. For the kingpins, just take the nut off the pin and knock it out.. i used a punch to knock it out. Im pretty sure the kit i bought had new lock pins in there so i really didnt take caution on messing them up.
Daniel
1953 Chevrolet 3800 Stepside
| | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Thanks for the info Red, I tried the gentle rapping with a hammer, that hasn't produced any results as of yet. Was thinking I might try heating them up to see if that'll break the seal. Best of luck! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The lock pins for the king pins can be really tricky. I had to drill mine out. On my chevy, I am going to try using my ball joint/U joint clamp to press them out. | | |
