| | | Forums66 Topics128,032 Posts1,055,517 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 43 Member | | Member Joined: Dec 2001 Posts: 43 | After searching past topics, it looks like a SM420 will bolt to my 57 235 that currntly has a 3 speed that pops out of 3rd. Also looks like I'll need a longer driveline. Can someone confirm this? A fellow bolter' has offered me a 420, that was working fine when he pulled it.
57 3100 235 3 spd
#8044 11/11/2002 11:00 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, it will bolt in. I think the driveline is the same length. The 3- speed has a tailhousing and the 4- speed doesn't.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2001 Posts: 43 Member | | Member Joined: Dec 2001 Posts: 43 | Thanks for the reply 4.
Excuse my ignorance. But if I take off the 3 speed w/ the tail housing and put in the 4 speed w/o, wouldn't there be a gap where the tail housing was. I must be missing something.
Thank you.
57 3100 235 3 spd
| | | | | Joined: Dec 2001 Posts: 43 Member | | Member Joined: Dec 2001 Posts: 43 | Drive shaft! I meant drive shaft! Not drive line. Sorry about that.
57 3100 235 3 spd
#8047 11/12/2002 10:07 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The 4 speed is longer than the 3 and takes up the space.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | I disagree on last post. 4spd is shorter, and requires a two-pc drive shaft too. Is yours the ball end for tork tube type or the flanged type with park brake on it, or has a yoke on it? If has yoke or flange, will need a slip joint somewhere, so needs second joint for that. Even the tork tube shafts had two pcs. I think if you have tork tube with 3spd, you would need whole rear from a 4spd set-up. I would go with 4spd, change the rear to newer open line, get two pc shaft and make x-over to hold mid-joint. If you look in an assembly manual for the driveshaft from a short COE (5100model), you will see a sort-of one pc shaft with slip joint on trans end that is just like joint usually put in middle. That would be another possible method of attaching.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | hey acme, if u click on the little icon with the piece of paper with the pen over it, u can edit your post if you goof it up. I do it all the time with my posts... just letting you know. -Woogeroo | | |
