7 members (RoadsScholar, HandyAndy, Wayne67vert, Peggy M, moparguy, ESum, 1 invisible),
69
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,467 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Hello!
Planning a T5/open rear swap on my '53 3100. I have a 3:73 open rear from a '56 Chevy wagon from a previous project. I took a quick backing plate to backing plate measurement, and it was within 1". The ratio seems like it would be PERFECT mated with a T5 on a 1/2 ton truck.
I don't plan on doing any hard core hauling with the truck...it's more of a cruiser.
Has anyone else done this swap? Any watch outs, or reasons I should NOT use it?
I didn't measure that axle tube diameter, but that shouldn't be a major hurdle.
Thoughts? Comments?
Thanks...
Chris | | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Denny -
Thanks for the reply. I want to replace the SM420 with a T5 as well, so I will have to lose the torque tube as well.
Chris | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 3rd member will not swap. The Passenger 3rd member is smaller and more of a flattened oval shape. For a swap, you would need a '55-'62 Truck 3rd member, which will fit no issues. As far as using the Passenger rear complete, there's no reason it won't work any different than any other passenger car rear. The brakes are smaller than the truck brakes, but that's the only real issue. Positraction 3rd members are very common for that rear, if you were to consider one.
Bill Burmeister | | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Bill -
Thanks for the response. Do you know what ratios are available for the '55 - '62 rears? I'd really like something in the 3.73 range to work with the OD tranny.
Chris | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The standard ratio is 3.90, with a 3.38 (Hydramatic) and 4.10 (usually w/overdrive) as options. The 3.90 is the most common, and the 3.38 is the olny gear available as anew replcaement. The 3.90 will work perfect with the overdrive. You will need to weld up the axle pivots, but otherwise, it's a drop in.
