4 members (Wayne67vert, Wally / Montana, moparguy, Pete1946), 130 guests, and 1 robot.
Topics128,072
Posts1,055,903
Members48,429
#803386 12/04/2011 12:32 PM
I have a couple of Carter glass bowl fuel filters,(the ones that say "CARbureTER" on them, but I don't know where to get gaskets and/or filter elements for them. The one has the original type porous ceramic looking stuff in it, the other has a lot of air inside, they both need gaskets . Any Ideas?
Gaskets can be cut from Buna-N that's avalable from McMaster Carr in one foot square sheets.
As fur as the elements go you might post a picture of the filter and luck out. Some times guys have some new old stuff gathering dust on a shelf in the garage.
DG
Denny G
Sandwich, IL
I like those red top Carter fuel filters. Don't know if it's the same as a Moraine Durex filter gasket:
diameter = 2-1/8"
inner opening = 15/16".
If they are the same, I can send you a pattern for a Durex filter gasket. Send me a PM with your email address.
Carter filters are often on e-bay. You might find an element there.
If the bowl leaks, here is how fixed my leaking Durex filter body.
BTW - see this 1959 Cadallac Serviceman bulletin about reusing old cork filter gaskets -- lower right corner. It's true. My cork fuel filter gasket will shrivel up like a corn flake when I remove it and it dries out. Must cut a new one.
- Lonnie
My '54 3104
Riding in the Passing Lane
Filter elements with a gasket are available from Napa & Carquest. The element is a paper cartridge type.
1972 Chevy c10 Cheyenne Super
So that we can avoid the future rants about the "pimply faced kids behind the counter who can't even read a parts catalog that often are hidden or have be removed . . . "
Does anyone have a link to an on-line catalog or does anyone have a brand of gasket/filter and a part number and or a cross reference (for Durex filters)?
Might be good to start with the original GM parts numbers. All were Group 3.890.
> 986128 - 1940-'49 Durex filter (MPC)
> 5451937 - Element '40-'49 (MPC)
> 1337676 - 1940-'49 Durex gasket (Buick Farm) slow to load
> 5451936 - Gasket '40-'49 Durex ('54 MPC)
> 986399 - 1950 Durex filter - modified to #986640 in 1953 (VCCA)
> 986640 - Box of 12 '50-'54+ Durex filters ('54 MPC)
> 5452784 - Element '50-54+
> 5452822 - Gasket '50-'54+ Durex ('54 MPC)
Can someone with 1940's and early '50's parts catalogues supply any missing parts numbers?
<Filter pic>
Left to right ... Carter ... AC Repro ... '50-'54+Durex Moraine (with spring upside down) ... '40-'49 Durex Moraine (with cut-down Durex filter to fit)
Can't guarentee, but I believe that this info is mostly correct ...
The 1940-1949 Durex filter had a wingnut and screw through the glass filter bowl. The glass bowl of the 1950+ Durex filter was secured by a wire bale. I believe that the bowl on the 1953+ filter was a little shallower that the 1950-1952 filter because the deeper bowl did not fit on a '53 Powerglide car. GM changed to AC filters in 1956.
The bowl and gasket for the '40-'49 Durex filter, with the wing nut screw through the bowl, is larger diameter than the '50-54+filter. '50-'54 gasket is 2-7/64" diam. I cut the gasket for my Durex 2-1/8" - it is a snug fit.
- Lonnie
My '54 3104
gasket is Fel-Pro 12473, dia. 2"...don't have any info on element
Ed
Carburetion specialist
Wash the ceramic element you have in vinegar.
Gaskets can be made from a variety of materials. We generally use cork for the fuel filter gaskets due to the thickness required. Very difficult to cut the desired thickness in some of the other materials.
As to elements; Carter produced many different ceramic elements, all that are very close in size. Trying to get the correct one is difficult. Too small an element will not seal. Too large an element will crack the bowl.
Jon.
The Carburetor Shop
- Lonnie
My '54 3104
The same gasket(s) also comes with a filter/cartridge:
Purolator F59221, NAPA 3943, Carquest 86943
http://www.purolatorautofilters.net/resources/Popup/Pages/PartDetailPopup.aspx?partnum=F59221
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #805289 12/10/2011 12:19 AM
I got hold of the guy on the ebay link and I think I am all set, depends on how things work out when the stuff gets here?
