4 members (78buckshot, Ponchogl, Shardean, dt235sd), 79 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
#803811 12/05/2011 8:00 PM
What radiator will fit my 52-3100 on top of a 82 S-10 w/V6.& automatic tran? The steering box seems to be a problem with the radiator & the bottom hose. I would like to buy a new one. But where is the best deal? This is just going to be a driver. But I want it to look good.
CFG61 #805128 12/09/2011 2:05 PM
This is what I have for my 51: Walker Radiator Works
~Jim
CFG61 #811212 12/29/2011 5:04 AM
It is a Case radiator 4 core. I hope this is going to work! Open for comments. It has a 2 3/4" cap. Witch I will change to a 15 LB.Chevy cap. Take a look in My photo-bucket and tell Me what you think. It fits good maybe I can make it work.
CFG61 #816844 01/16/2012 8:50 PM
I found a radiator cap today that fits! I will put it all together and try it out. It is a 7 lb pressure.
CFG61 #816851 01/16/2012 9:19 PM
!5 lb is good if the radiator is good.The 7sounds better if you are using old goods.
CFG61 #819362 01/24/2012 9:26 PM
I put the case tractor radiator in and it fit and cools very good. The pic's are in my photobucket.
