3 members (wilbur53, 2 invisible),
71
Mod | | | Forums66 Topics128,109 Posts1,056,572 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | Hey guys,,have 5 questions for you,I put SBC in 65 chev truck,now putting new guages in,1(have electric auto meter oil pressue guage,there is a small metal tube going from the rear of block to under dash to instument panel,is this a mechanical oil pressure,did these trucks have mechanical oil pressure? I assume yes ,left signal light flashes faster than right,(ground issue?)why are dash lights so dim,is this normal?hood springs,will chroming them take the spring out of them,thanks | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | The tube is the oil pressure (Mine has the same thing) I dont think chroming the springs will hurt them. The other questions I am not sure about. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | 1. The small metal tube going from the rear of the block to instrument panel is the oil capillary tube, so there is technically not a sender, just the oil pressure from the oil galley in the block. If you are running an electric Autometer oil pressure gauge, you will need the corresponding oil pressure sender, to match your gauge.
2. I am not sure why one would flash faster than the other, but grounding is a very common issue with the lighting systems on these truck. Check current at the sockets, to determine, for sure if it is voltage, amperage or ground.
3. The headlight switch has a rheostat in it and by rotating it counter-clockwise, the dome light will light and by rotating it clockwise, the dash lamps will dim, so you need the switch rotated counter-clockwise, just before hitting the detent, thus the rheostat is in the highest setting and the lights are at maximum brightness. Have you checked the sockets on the back of the dash cluster, to be sure there are no faulty bulbs? This will cause the backlight to seem dim.
4. Chrome-plating or powder-coating the hood springs will not cause them to loose their optimum spring-rate. | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | The only potential problem with chroming springs is hydrogen embrittlement which can eventually cause the spring to fail if not baked correctly to relieve the hydrogen. I first became aware of this back in the 1970’s when I worked for Peterbilt. One of the major wheel suppliers to the industry dropped all chrome wheels from their line due to failures in the field. I’ve also seen chrome hot rod axles and suspension springs break in service. Of course I’ve also seen about a zillion chrome springs that didn’t break, and losing a hood spring isn’t the same as breaking a suspension part. It’s just something to consider. Here are a few links explaining Hydrogen embrittlement: http://www.bikeguide.org/guides/chrome/http://www.finishing.com/1600-1799/1747.shtmlhttp://www.nmfrc.org/crarchive/jun06a.cfm | | | | | Joined: Oct 2005 Posts: 116 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 116 | I would suspect the cause of one side blinker light flashing quicker than the other to be a burned out bulb on that side ? Easy enough to check out !
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | "The most vulnerable are high-strength steels, titanium alloys and aluminum alloys."...none of which apply to the hood springs found on these trucks. Endura-shine may be the powder-coating alternative, if there is a concern of hydrogen embrittlement.
Thanks for the information, Markeb. Interesting read.
| | | | | Joined: Dec 2010 Posts: 41 New Guy | | New Guy Joined: Dec 2010 Posts: 41 | thank you gents,will check out your suggestions on weekend,thanks for your time, | | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | I had the same problem with one flasher blinking faster than the other. It frustrated me to no end figuring out what was causing it. In the end it was the headlight switch and the rheostat. By turning the switch it corrected the issue and the flashers blinked in the correct fashion. I would go right to the switch first as I tried everything else first (voltage, grounding etc) and it was as simple as turning a switch.
1964 K10 Fleetside Pickup Truck | | |
