11 members (Gdads51, dt235sd, Gray_Ghost, Woodcmiami, Shaffer's1950, Nick in Manitou, Jon G, Otto Skorzeny, Hotrod Lincoln, walter74, 1 invisible),
70
Mod | | | Forums66 Topics128,131 Posts1,056,372 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 14 New Guy | | New Guy Joined: Apr 2011 Posts: 14 | Hello to all of you this morning.I have a 1955 GMC 100 2nd series that has a OEM style blinker assembly that looks like this one from american classics http://www.americanclassic.com/images/TSA57.jpg. 1st question I havent been able to find any schematics to identify which color wire is what so I can try and get these to work I did replace the flasher unit already just to make sure. 2nd question the white wire that comes out out of the brake switch is white and looks like it runs to the steering coluum. The feed wire into the switch is orange and is hot all the time. I took a meter to the switch and it seems to be working fine but I dont have any brake lights at this point either any help or suggestion you all might have I thanks you for in advance. Fred | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | schematic last page here ... the feed for the tail lights goes via the signal switch, which simply interrupts the selected light, your lack of brake lights is likely some other part of the brake circuit - if you don't have the shop manual wiring diagram, the Chevy one might workBill | | | | | Joined: Apr 2011 Posts: 14 New Guy | | New Guy Joined: Apr 2011 Posts: 14 | Squeese, thanks for the info all keep everyone posted. Thanks Fred | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | ... the feed for the tail lights goes via the signal switch, ... Bill That should read 'the feed for the brakelights goes via the signal switch'. The feed for the tail lights goes via the headlight switch. | | |
