5 members (Southerntruck, RoadsScholar, 50Chevy3100, NorthCoast3800, Gray_Ghost), 118 guests, and 3 robots.
Topics128,100
Posts1,056,514
Members48,448
I hope This is the right forum for this.
I need to know the thread size and type in the bottom of the gas tank.
It looks like 1/8 " NTP but want to be sure before I crank a fitting up in there.
I am making my own fuel line run instead of using original fittings etc.
If it's stock then it should be this:
http://www.pbase.com/dennygraham/image/115771643
DG
Denny G
Sandwich, IL
Thanks a bunch Denny
It looks like mine has been changed then.
If ya post a picture of what ya got we can probably help ya out.
If its a one of those offshore replacement tanks then they've been coming thru with
Metric threads in them, BIG problem.
DG
Denny G
Sandwich, IL
I think you might be right about it being metric threads. I screwed a 1/8" nipple in, It went in but I could tell it wasn't right. Its not leaking so I,m going to leave it alone for now. If worse comes to worse I,ll drill it and tap it to 1/4 inch pipe.
Thanks for your input.
