7 members (Otto Skorzeny, baldeagle, 1955 1 Series, Rusty Rod, dt235sd, Woogeroo, Hotrod Lincoln),
364
Mod | | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | So, underneath the back of my beloved bus, is a sort of ramp. What the heck is my spare carrier supposed to look like?
I realize a picture would help my cause here, and I'l take one for tomorrow.
I don't even have a spare rim right now, but I came to the sudden realization that i'd better figure this out before I put a trailer hitch on. I wouldn't feel too cool if I couldn't put the spare up there, if I stuck the hitch in the way.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Yeah, I'd read that when I did a search. I do try and search things instead of driving you guys nuts. What I have doesn't look like what's pictured, but it could be, that I just don't make the connection in my brain. Here's a crappy picture of what I've got under my truck. I'll take a better one tomorrow. I've got this part that runs fore and aft. And I do have that mystery hole in the back of my truck, next to the barn door latches. http://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP1587-1.jpg | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Ahh okay. I was confused, as Chevs of the 40s lists just one type, and the filling station lists a separate kind of the panel trucks and suburbans.
Frankly, they all cost far more than I'm willing to pay right now. I just don't want to put my hitch in the way of the tire's future home. Might not have a choice though.
Thanks. | | | | | Joined: Mar 2011 Posts: 153 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 153 | My 48 burb came with dual exhausts and a trailer hitch that completely occupied the space of the original spare tire carrier. The hitch was welded to the frame. I cut and ground off the trailer hitch and removed the exhaust pipes. Starting from the same point that you are at, Christopher, I added the original spare tire carrier from my pickup (with spare tire) as a reference to use when running a replacement single exhaust pipe. You are correct to be concerned about a trailer hitch crowding out your spare. The mystery hole is to accomodate the top nut of a threaded rod that holds up the tongue of the spare tire holder. It serves the same function as the spare tire hook that fits into a hole in the rear bed sill of a pickup. You could easily fabricate one by grinding the rounded contour of the inside of the mystery hole onto the bottom of a large nut threaded the same as a 5-6" stud. 1/2-13 I think. Add a washer and another nut to the bottom of the stud and there's your mystery hole to spare tire holder connection. Unfortunately I don't have a digital camera so I can't snap a photo. I valued the stock spare tire carrier over the trailer hitch but I think that you are correct that it's one or the other. Good luck! Dave
1946 Chevy pickup, 1948 Chevy suburban, 1950 Chevy pickup, 1952 GMC pickup, 1957 Chevy pickup, 1939 Chevy pickup
