4 members (Samantha, KEVINSKI, mk72, 55shaker), 91 guests, and 2 robots.
Topics128,035
Posts1,055,552
#802712 12/02/2011 1:24 AM
but now I've more questions. Are valve rotators worth keeping? What about the double thermostat?
'53 BelAir 261 3spd/OD 4dr
'54 3100 235 3spd
'79 C30 with a '51 235-'57Bellhousing-'67SM420-14bolt dually
'89 V3500 350/465/205 SRW CC
One Chevy just isn't enough.
DADS53 #802731 12/02/2011 2:29 AM
I like valve rotators. I see nothing wrong with them unless you are planing on turning some high RPMs, in that case there heavier weight could cause valve float.
My Blog
Thanks Dave,
Hey, are you the one selling the water-pump adapter plates on ebay?
'54 3100 235 3spd
DADS53 #802792 12/02/2011 4:56 AM
That would be me:)
My Blog
I'm pretty sure I'll be getting one of those soon. Just gotta find the right engine to put it on first.
'54 3100 235 3spd
DADS53 #802802 12/02/2011 5:20 AM
Nothing better than a 261!
My Blog
As far as your 261 thermostat question, I would not worry about using one if the engine is only going to see light duty use. Another thing, 261 thermostats are getting hard to find.
My Blog
The thermostat or the housing is hard to find ?
1951 3100 Chevrolet
Both, if you are referring to the 261 special thermostat. It is a non-standard-design thermostat (no one has posted a source of a replacement - a while back, someone posted a name for the special design) and I think it goes in a special housing (that will allow for the larger thermostat-height).
Regular 235 thermostat housings will work on a 261 but I think that they will not allow an original thermostat to fit inside. An original 261 housing will, I think, allow a normal 235 thermostat inside.
Also, the thermostat housing (and water pump) that came on one of my 261s (1960 from a large school bus) have an extra hose connector on the thermostat housing and on the water pump. I guess that they might have been used with a rear heater in the bus?
The 261 in my truck came from a 1960 school bus. It had two heater hose connections....one off the thermostat housing and one off the water pump, then it also had a bypass hose that went from the thermostat housing to the water pump.
And I love the 261.
This engine has two hoses coming out of the thermostat housing. Normal looking bottom half, top half has a hose coming out the pass. side then another half-sphere lump on top of it where the rad. hose comes out.
Oil filter mounting flange is part of the lid, looks to be aluminum and has three ports 1-in & 2-out. Is this a good one?
Carb. is not one I've seen before. 1V with the bowl forward like a carter but not rectangular, more rounded "D" shaped. Quite a few plumbing fittings coming off of the intake vacuum port.
It's a 3rd party sell so exact info is sparse, says it's got 10k on a rebuild. For what that's worth; I got burned last time I fell for that on my '58 engine.
'54 3100 235 3spd
DADS53 #802871 12/02/2011 3:16 PM
DADS53,
Here is a photo of the 58-63 261 oil filter assembly (the filter head/top/cap is as you describe, I think).
http://lh3.ggpht.com/-tkTLlRE_wHA/Svjv70H3yOI/AAAAAAAAABk/sVobcFpGa24/s640/IMG_4359.JPG
That is a full-flow filter - the only factory full-flow GM filter used on cars/trucks (Chev & GMC) in those years.
Yup, that's it.
'54 3100 235 3spd
DADS53 #803167 12/03/2011 4:55 PM
What is the rod directly above the steering column with a cleavice end on it?
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
