| | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I am rebuilding the 3 speed shift box on my '52 1/2 ton GMC that is mounted at the bottom of the steering column. Does anyone know what type grease it is supposed to be filled with? I could not find any mention in either the Chevy or GMC shop manuals. Mine looked like it had wheel bearing grease in it. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | A lot of people use "Corn Head Grease" purchased at Tractor Supply or John Deere. It's a farm impliment grease.
Drew
| | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I have used that in my steering box, but was not sure about using it in the shift box. I am a little concerned that it may tend to leak. Has anyone had first hand experience with it?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if the rubber boot is present and in good condition there should be no problem with leakage with any "self leveling" grease like Cornhead Grease - I've always used a moly grease and it works fine sticking to the metal in extreme heat applications, the parts don't move far or fast but it can get hot next to the engine .... also, contrary to the wording of the manual, I wouldn't "fill" the box with grease
Bill | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | Thanks for the information. | | |
