2 members (papas52, 2-Ton),
110
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80244 07/20/2007 9:29 PM | Joined: May 2005 Posts: 19 Apprentice | | Apprentice Joined: May 2005 Posts: 19 | I saw this short video on Jay Leno's Garage. In the four minute seqment Jay and his mechanic discuss options for dealing with modern gasoline. My question comes from one comment where Jay mentions to add "top end lubricant" to the gasoline. What is "top end lubricant". Jay also suggests Automatic Transmission Fluid as an alternate additive (8 - 10 ounces) to the gasoline. What ratio is correct if this method is used? Here is the link: http://www.jaylenosgarage.com/video/index.shtml?vidID=126269
"Nothing within the realm of the restoration process shall be alien to my experience"
#80245 07/21/2007 3:12 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you're looking to preserve the gas for long term storage, you'll want something like Sta-Bil, which is a feul stabilizer. For top end lube, Marvel Mystery Oil (yes, it does work) or Lucal Feul Treatment is what you'ld want to use. The correct ratio of stabilizer/top emd lube to feul amount is listed on the container. Usually about 3 oz. to every 10 gallons of feul.
Bill Burmeister | | |
#80246 07/21/2007 1:26 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Sambear...you've asked a good question. Car collectors need to be very aware of this issue. If one stores their collector rides for the winter and don't do something like 'longbox55' suggest anything from gummed up carbs to bent pushrods may greet you in the spring. The oldtimers know all of this but as 'newbies' get their rides running, they need to get the heads-up.
#80247 07/21/2007 5:41 PM | Joined: Mar 2007 Posts: 16 Junior Member | | Junior Member Joined: Mar 2007 Posts: 16 | A collector I know with a substantial collection (not near the size of Leno's) uses a quart of 30-weight motor oil for every 10-gallons of gasoline in his pieces that are started and brought up to operating temp every 90-days to keep gaskets serviceable. He says that's the only method he's found that stabilizes gasoline for long periods of time. On his museum and long-term storage pieces there is no gasoline in the systems. | | |
#80248 07/22/2007 11:23 AM | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | thats funny oil in the gas is what makes gas varnish up nothing smells worse then old saw gas | | |
#80249 07/22/2007 4:06 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Got Sears, lawn boy, and no name B&S push mowers, a Sears rider and three weed whips, two chain saws and a blower and they sit all winter, with fuel in them and start up fine in the spring, 38years now for some of them, wonder why? Bought a Coleman 5000watt generator in 2000 for the 2k disaster filled it up and start it once a year and run it for 10min. Original gas from seven years ago, wonder why? I think the myths about varnish and only using fresh gas a few months old are fruit for urban legends. Had a F-150 that sat behind the barn for 15 years and I would start it up only when I needed a load of dirt or lumber, i.e., every couple of years, it always started. That said, I have used "Sta-Bil" in everything that sits including my airplane for 25years when I talked to the guy that invented it. At the time he was mixing it up in his garage in Chicago and packaging it there. Since then it's been sold to Gold Eagle who also own "Heet" Denny Graham Sandwich, IL
Denny G Sandwich, IL
#80250 07/23/2007 10:06 PM | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | I have had only one experience with gas going bad over the winter and it was with a motorcycle. That gas did not varnish up everything, but the cycle just would not run right (missed, quit, poor idleing) until I got a new tank of gas in it. FWIW: I was told in colder climates, gas going bad is less frequent than in warmer climes. | | |
#80251 07/24/2007 2:16 AM | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | I'm pretty sure temperatures have a lot to do with it. Snowmobiles usually give me fuel system greif unless it's parked either completly empty or completely full, stabil or not. Seems my trucks are more inclined to give me problems if they sit through the heat of summer as opposed to cooler times of the year. It also seems to me that in recent years, gasoline is harder on rubber parts and hoses than it used to be, turning them into sticky mush.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
#80252 07/24/2007 3:45 AM | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HI...can Marvel Mystery oil be used along with Sta-bil and is there any danger of the combination hurting the old Rodchester B carb? T/C and thanks, Steve | | |
#80253 07/24/2007 12:27 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I don't think there is anything that can hurt a Rochester "B" carburetor any more than it hurts already!!! If you have a “B” that is not leaking fuel into the throat and Ooooozing or weeping out of the sides then your one in a thousand, don't touch it or do anything to disturb it!! There shouldn't be anything in either one of the additives that could hurt anything inside the carb Steve. Basically there is only a gasket, a Viton needle, and the pump leather in these, a real simple carb, no rubber inside. Denny Graham Sandwich, IL
#80254 07/24/2007 2:07 PM | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | YEP...it works great I had it re-built by Re-carbo here in CA thanks for the advice Denny and T/C Steve | | |
