0 members (), 172 guests, and 3 robots.
Topics128,196
Posts1,057,395
Members48,471
This subject comes up often and I would like to see the different carriers in one post for future reference. Whose got some nice detailed pictures of their tire carriers? 1/2 * 3/4 * 1 ton, suburban and panels. I will look for some of those that have already been posted, but I could use some help. Factory photo's are good too.
Thanks to:
Achipmunk
Denny Graham
Jim's 53
oldblu51
oldcarmanualproject.com
Woody Vondracek
and others who I failed to thank!
WORK IN PROGRESS:
I need some confirmation on if the 1/2 Truck shares the same Tire carrier as the 1/2 suburban. Can anyone show any differences if there are any? Thanks
Rear Sill: Top View Pre-1951 rear sill (Suburban/Panel/Canopy Express)
Rear Sill: Bottom View Pre-1951 rear sill (Suburban/Panel/Canopy Express) Barn door version.
Rear Sill: Bottom View 1951/1954 (Suburban/Panel/Canopy Express)
Tire Carrier: Parts Numbers (Page 1) & Page 2
Tire Carrier: 1/2 Ton & 3/4 Ton Illustration
Tire Carrier: Installed Pre 1951
Tire Carrier: Pre-1951 underbed tire carrier receiver.
Tire Carrier: 1948 installed view.
Tire Carrier: 1951/1954 Complete assembly.
Tire Carrier: 1951/1954 Complete Assembly
Tire Carrier: 1951/1954 Installed (Suburban/Panel/Canopy Express)
Tire Carrier: Pre-1951 1/2 & 3/4 Ton Factory Photo
Tire Carrier: 1951/1954 1/2 Ton & 1 1/2 TonFactory Photo
Tire Carrier: 1951/1954 Factory Photo (3100)
Tire Carrier: 1954/1955 Factory Drawing
Tire Carrier: 1951/1954? Factory Photo (3600)
Tire Carrier: 1951/1954? Factory Photo (3800)
Tire Carrier: 1948/1955 Installed Tire Carrier
Denny Graham's Album - Tire Carrier Installation
Tire carrier:
Quote
A bit of research yeilded this:
The 3681633 strap is the same 1946 to 1950 ½,¾ TON (CAB, PICKUP, FFC). The Track is different, 41-50 ½ TON uses a 3658388 Track and the 41-50 HR (CAB w/PICK-UP, PANEL) used the 3658432 Track.
The 3697278 cross strap is the same 1951 to 1953 COMM but is replaced in later parts books by 3703308, which list the 3703308 strap as the same 1951 to 1957 COMM (exc. SUB.PICK-UP) cross (44 5/8 O.L. ). The SUB.PICK-UP was the 1956-57 model 3124 (Suburban Carrier/Cameo)
In the earlier parts book for the 54 COMM there was a 3704266 diagonal cross strap (14 holes 5/16) but it looks like it was also replaced by the standard cross strap 3703308.
I see no listing for straps or tracks which are the main carrier parts for the SUB.CARRY-ALL in either the 1929-54 or the 1929-57 parts books. Is it possible that the spare was carried inside the truck?
Denny Graham
Sandwich, IL
How about a modern conversion:
Quote
carolines truck
Because we're gettin older and I really wanted mine on the fender, so did the ms's ...
we didn't do this tech conversion, so I put it here back under and feel much better about when the time comes and Caroline is alone having to change the darn thing out
she CAN
I have a very simple crank down cable
http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=24-1.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=23-1.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=20-1.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=2748800-R1-E026.jpg
To operate the rear spare tire and DON'T HAVE to groval in the wet/snow/mud/rain/dirt 10 days or 10 years from now to lower the spare tire when she gets a flat && she can also. Which is where MOST put their after-market gas tank.
THAT's what makes all this work
say you do the fender tech thing and later on you want a different tire, and maybe it won't fit that fender work you did.... what then
IT's a whole game plan when you think about what it is, when one does work to a truck that we'll keep forever .... YOUNG
PRE-1951 TIRE CARRIER The fourth picture is from a post 1950
