7 members (FishinToms53, klhansen, Otto Skorzeny, Southerntruck, Mike B, Robert Crandall, Peggy M),
95
Mod | | | Forums66 Topics128,118 Posts1,056,646 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 153 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 153 | I'm at the reassembly stage with the rear doors. When I took this all apart 5 years ago, there was an old weatherstripping piece attached to the lower inside edge of the top liftgate where it would rest against the top outside surface of the lower tailgate. I don't know if it was factory applied or added by a previous owner to cut down on rattling. I have a reprint of suburban-specific factory parts and I see no mention of rear clamshell weatherstripping nor can I find any for sale from the aftermarket parts dealers. But it seems as if this area will leak air and wind-driven water like crazy! It also seems like any weatherstrip added to the lower tailgate wouldn't last very long in real world use. Maybe in 1948, Chevy wasn't worried about air and water infiltration through the rear doors. Has anyone else added additional weatherstripping and if so, how? Thanks, Dave
1946 Chevy pickup, 1948 Chevy suburban, 1950 Chevy pickup, 1952 GMC pickup, 1957 Chevy pickup, 1939 Chevy pickup
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Pine tree I am in same stage as you on my 49 burb w clamshell. It has no weatherstripping. I am just getting it back on the road and it rattles like he//. I think my issue may be upper hinges. Can someone please post pictures and comments on how to correctly fix the problem? Thanks.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: May 2007 Posts: 321 Shop Shark | | Shop Shark Joined: May 2007 Posts: 321 | I am planning on using the same weatherstripping that I used on the doors for the rear. When I bought the burb, it looks similar to that stuff when I pulled it off, plus it seems to be a decent fit.
| | | | | Joined: Mar 2011 Posts: 153 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 153 | I did some additional digging in the GM replacement parts archive and found that there was replacement weatherstrip sold in a 60' roll. Armed with the awareness that weatherstrip was indeed called for, I improvised my way through sealing all the way around the upper end gate and the side and lower edges of the lower end gate. I used some leftover higher-profile weatherstrip that the previous owner of my burb had mistakenly bought for the front doors. In one area, I cut and sanded off a part of the weatherstrip profile that was too high. In another case, I glued the weatherstrip on upside down. Whatever it took to get a profile to suit the need at hand. The whole area has a nice, snug feel to it when both gates are closed now. It looks pretty decent too. Also, I made some replacement rubber bumpers for the sides of both gates as the originals were shot. I also elongated the mounting holes on both endgates where they attach to their respective hinges to give some vertical or lateral movement to suck up some of the slack or minimize binding. Everything is a compromise between the ideal and the real. Dave
