2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#80179 07/18/2007 8:06 PM
All,
I have posted pictures of the beginning of my next vacation project - 46’ gas tank. Step 1 is complete and I know what I have to work with. Interested to know if anybody could offer suggestions on getting a lower half made, if they have done it, etc. I am still resigned to factory under seat tank although I have a solid plan for an alternative frame mount already in place. Not giving up just yet.
Are the old tank halves, drain valve bungs, and filler neck soldered in. Any of this info would help immensely.
Brett
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
Brett,
I viewed your tank pictures. My opinion is you are doomed. Your time and money would be much better spent having a competent sheet metal shop make you a new tank. If you are 'weld-smart' and own a small MIG machine, you can have 16 or 18 gauge panels sheared and formed, then weld them together yourself. You can purchase weld flanges and install them where you want your pipe fittings to go. Your chances of a leak free tank are improved immensely when you start with new material and lap weld the seams. My two cents!
Stuart
Junior Member
Junior Member
Cavebull, do you know anyone coming to Central Florida soon with a pickup truck? I will GIVE you a decent 1940 1/2 ton tank which was holding gas and has surface rust only. I would still seal it at a minimum.. I am moving away from the in-cab tank.
Dan Friend 386-943-9537 leave message, or email me at [email protected]
