5 members (Guitplayer, 50Chevy3100, Otto Skorzeny, Hotrod Lincoln, TUTS 59), 154 guests, and 0 robots.
Topics128,105
Posts1,056,209
Members48,436
#8012 11/27/2001 2:29 AM
anybody know what the redline for a 248 is? what about normal cruise r.p.m.? may have found a ring and pinion set for the differential but i think at 3:70 to 1 i think it may be too tall. cool
#8013 11/27/2001 2:46 AM
I do not know what the redline is, but I think the 3:70 gears would be fine. (the bigger the number the Lower the gears)
#8014 11/27/2001 2:57 AM
oh yeah--the truck is a 1 1/2 ton 51 g.m.c. cabover.
#8015 11/27/2001 7:13 AM
If you've got a good motor...25lbs hot oil pressure I'd say 4500 TOPS!!
2/3s of any redline is a good rule for just driving
Mine runs at 2200 'bout 70-75 and likes it
#8016 11/27/2001 7:28 AM
JH, What gears are you running?
#8017 11/27/2001 7:31 AM
Jim's right on the redline on these old sixes, but I sure wouldn't run one that fast for very long. Cruising range between 2000 and 3000 rpm, stick in the 2000 to 2500 range for economy and engine life, higher if you are hauling heavy loads uphill.
Fred
52 3600
69 C-10
#8018 11/27/2001 8:03 PM
I run a 3.90 with tall tires and a FooG T-O/D
trans 4th is an overdrive
I used a Chevy ten-bolt truck re in the 39 housing
#8019 11/27/2001 8:49 PM
Redline? a stock GMC can't rev high enough to hurt itself lol.In bigger trucks, that series of engines usually has governors set around 3200 rpm.I bet the drivers ran them wide open against the governor.GMC's are supposed to be more rugged than Chevys.I had a 54 Chevy in high school. Used to run it wide open for miles in second gear trying for 60mph.Never blew and oil pressure guage never moved past the 10 psi mark. also never hit 60 in second.Just run that Jimmy wide open. Jim Proffit says the long motor can take it.
[ 11-27-2001: Message edited by: Tony ]
#8020 11/27/2001 11:31 PM
10 psi oil pressure on a '54 engine? Is this low for a'54?
#8021 11/28/2001 12:14 AM
35 or higher is normal.I didn't even know that was low oil pressure until an adult told me.That single statement has caused a lifetime of oil guage watching and fear of unscheduled engine disassembly.
