| | | Forums66 Topics128,100 Posts1,056,515 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | it fills like a vacume leak it hesitates. but i cant find a vacume leak. fuel lines are tight.1/3 of a tank of gas little hesitation fill the tank full it can harly run is it the fuel pump.pump is one year old 400 miles on it.thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | not a very clear question oldguy, but you might want to check for junk from the tank in the carb, or a plugged filter, or maybe you need a filter
Bill | | |
