4 members (UtahYork, BC59, dt235sd, 1 invisible),
97
Mod | | | Forums66 Topics128,211 Posts1,057,469 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 6 New Guy | | New Guy Joined: Oct 2011 Posts: 6 | I have a 1952 chevy truck. I am gone to swap frames with s10 and put a 5.3 chevy engine and auto transmission in it.I am wondering about wiring will it match the s10 ? should I get automatic s10? I have herd guys using steering colums and brake pedalsand wiring harness.Is there problems with 1994-2004 steering colums orshould i go with 1983-1993.the other question is about the newerbrake pedal harder to fit because of cast frames. sorry for all the question just want to get right year and first build to. | | | | | Joined: Oct 2010 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 28 | sparky check out the guys over on the 67-72chevytruck.com site. There are a ton of guys who have done this exact swap.. Good luck | | | | | Joined: Oct 2011 Posts: 6 New Guy | | New Guy Joined: Oct 2011 Posts: 6 | | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | sparkysmile you can also checkout killbillet.com. it is a rat rod site but lots of s10 swaps with pictures for AD conversions.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Hey new guys, the HAMB has many S-10 swaps as well as on here. I myself went down that path however the whole cooling system vs steering and the fundamental first law of physics pushed me back to a stock frame with my crossmember kit on it for my '53. In fact I traded a rolling S-10 frame with custom isolator mounts for the cab for a stock '53 3/4t frame without axles
Sparkysmile, there is not much different between the 1982 and 2002 frames on an S10. you will need to rewire everything - old truck, s-10 frame with LS based motor. your best bet is a new wiring harness to start with.
