2 members (Hotrod Lincoln, Tronman), 167 guests, and 3 robots.
Topics128,257
Posts1,058,017
Members48,479
1 Offline
I am restoring a 53 3100 half ton. It has the original 3 speed transmission and closed axle. Can someone tell me what type of fluid I should use for both the transmission and rear axle? Thanks
1953 3100 Chevy 5 window
1971 Chevelle SS
SAE 90 gear lube.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
1 Offline
Thanks, so I should use SAE 90 for both the rearend and the transmission?
1971 Chevelle SS
That would be a yes...!!!!!
