6 members (GRNHydra, Oswald, Southerntruck, 1955 1 Series, Nick in Manitou, Wayne67vert), 122 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
I found myself having to replace the wiring on my 65 C10 on the right tail light. I replaced the fixture also with another I had lying around. Now brakes lights work, parking lights work but when I use the left signal both sides blink. The right... nothing blinks. headscratch
Any clue(s) as to where I should start tracing the wires?
Thank you
Tim
Check both tail/brake light sockets for grounding. One side will show a high resistance, or no ground at all. Rusty mounting hardware or a bad connection between the bulb socket and the housing is the most common cause of what you're describing.
I will check the d/s since I replaced the p/s yesterday.
Thank you for the reply.
Tim
Dumb question. What is d/s and p/s?
Driver's side- - - -Passenger's side.
I've created a few problems when I installed something electrical, so now I make it a practice to recheck the last thing I worked on before chasing gremlins everywhere else!
sounds to me like the ground is bad on the ds, since the ps works
the ds is grounding on the ps since it comes on too?
6tvette,
I will give that a try.
Thank you
Tim
