1 members (carbking), 77 guests, and 3 robots.
Topics128,196
Posts1,057,393
Members48,471
Darn this title thing, its just no long enough.
I've just got a simple and quick question.
My local flaps seeps to be all out of shock-oil, hahaha, and I need to fill the dual action shocks on the panel.
Now, I've seen some people use jack-oil, but can I just use 30 non-detergent? I ask, 'cause I'm sure my shocks will seep, and I always have a pail of that stuff around the shop here.
I'm sure I'll need to rebuild all four shocks, as there is some play in them right where the arm attaches, but for now, I figured I'd better put some oil in there so I'm not driving around with them dry.
These are my first lever shocks, and I'm pretty excited about them.
Thanks!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Riding in the Passing Lane
Ive always put hyd. jack oil in them. I suppose you could use engine oil but never brake fluid.
1972 Chevy c10 Cheyenne Super
I think the biggest issue putting engine oil in the shocks is foaming. The extent of that depends on how much action it sees. Putting around town probably not a problem. Rough roads of fast on not a smooth road would be a problem, more so the longer you drive.
40 Chevy 1/2 ton
Well, I've gone ahead and put the engine oil in them for now. The foaming was what I was wondering about too.
But, mostly I just wanted something in there, until I get a chance to take them apart and work on them, which will be awhile. There are a few other more pressing issues, I just wanted some kind of oil in there!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
You will find shock oil at your local friendly motorcycle store. They sell it as fork oil and it comes in different weights for soft or hard ride. Always wondered if automatic transmission fluid would be appropriate?
I always use ATF, 30w may make them a little stiff.
My Blog
Heh heh. I'm not sure if its bling to make any difference..... Sure is allot of oil laying on the shop floor!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
G M lube specs suggest 'light fluid'.
Back when I was racing Brit sports cars, we used a 30 weight/STP mix in our shocks. It helped to wear a kidney belt on a rough track!
