0 members (), 108 guests, and 2 robots.
Topics128,035
Posts1,055,560
#80062 07/16/2007 4:20 PM
Just finished my T5 transplant into my 46 this weekend. Took it for a little drive Sunday and it works great.
With all the information I got from fellow bolters the switch went without a hitch. I had no problems with the adaptor plate from Buffalo. I used a 9 1/8" clutch for a S10 and a 55 pumpkin (3.90)that I put into my orig. rear end. I built a bracket for the parking brake and the rear cross member per Stepenwood's tech tip. (Thanks John)
All that's left is to make an original looking stick and put a boot around it. This is going to be a great improvement to my truck. I'm happy with it.
What's next, you may ask. Well maybe dual Carter/Webbers grin grin
Thanks All
George
#80063 07/16/2007 8:16 PM
Congrats!!! I can feel your joy!!! Nothing like reaching over and sliding it into 5th gear and feeling that engine settle down to purr!
The only problem I've found with the T5 is that it opens the door for a lot more refinements that will add to your cruising pleasure. The Carter/Webers are the logical next step and we've pretty much got them figured out too! They sure eliminate most, if not all the typical carb problems from the old stock carbs and the setup offered by the Stovebolt Engine Co. works like a charm. Happy motoring!!!
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#80064 07/16/2007 11:15 PM
George -
Good news! grin Great to hear you got it done, especially with out any problems!
Joe smile
