| | | Forums66 Topics128,049 Posts1,055,701 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80060 07/16/2007 9:58 AM | Joined: Jan 2007 Posts: 21 Junior Member | | Junior Member Joined: Jan 2007 Posts: 21 | I have a 1947 2-ton, it doesn't run at the moment but I do know that the timing is off, according to the previous owner. I want to know how I can adjust the timing back to stock specs. The engine is a 235 but it's the low oil pressure 216/235. Bear in mind, I really have no mechanical know-how. I know body work mostly. So if anyone can help me out, or send me a link to something that could help I would be very grateful. | | |
#80061 07/16/2007 3:31 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I will assume that the distributor has not been removed. Set the points for .018" at the lobe on the cam and then rotate the flywheel until the steel ball is at the pointer. This is seen through the hole above the starter. The steel ball is very tiny and I had to crawl underneath, take the inspection cover off and then mark it with chalk. Anyways after lining up the ball, undo the bolt that holds the distributor from turning and turn it as necessary until the points are just opening. That is where you want it. | | |
