| | | Forums66 Topics128,193 Posts1,057,246 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 33 New Guy | | New Guy Joined: May 2011 Posts: 33 | the tag on the carb. 3688154 what does this mean. have velve cover off and poured ton of gas additive on everything.when i have used a gas type additive type product for all this because it was free.in spark plug hole i get it to overflow in each one. before i bought it in may it did turn over. i have been injured,so it goes slow.my wrench man & have not gotten together yet. thanks for any help regards, qx | | | | | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | QX Welcome to Stovebolt. OK, you said that in May, before you bought it, it did turn over. So the motor is not stuck, right? Or is it stuck now? I'm confused why you put the additive on everything under the valve cover. Are you using that as a cleaner or penetrating oil to loosen rusted or stuck parts? And what about the additive in the spark plug holes? Have you filled each cylinder full of additive? Has the truck sat for a long time not being run? Does it have a battery? Is it full of oil? Somebody that knows carburetors will have to comment on the tag number. That model truck should have a Carter "W" I think. Do some research on this site http://chevy.oldcarmanualproject.com/chevyresto/49index.htmand here http://chevy.oldcarmanualproject.com/shop/1948_51truck/index.htmDescribe better what's going on and hopefully we can help you. Good luck.
Professional Novice
