6 members (Hanks custodian, Chris's 46 / 515, carbking, Goach2, mick53, 1 invisible), 69 guests, and 6 robots.
Topics128,188
Posts1,057,215
Members48,465
Junior Member
Junior Member
I was showing a friend my chassie of my 68 and told him that I was sticking a 305 with a turbo350 between the frame rails and he tells me some stuff that I didn't want to hear. He said that he thinks that I will have to replace the tranmission crossmember to be able to use the transmission that I have.
Does anyone have any some better new than that? I would like to here that it will work with the stock one, but I want the truth what ever it may be.
God is good all the time and All the time God is good.
3B Offline
Hy JarridLem, Turbo 350s have at least two different tailshaft lengths, possibly three. If you use the transmission with the correct tailshaft length , everything will drop right in, hope that helps.
Riding in the Passing Lane
Seems to me if you have a manual trans. now you will have to pull the crossmember under the bell housing & put one under the rear of the trans. You could bolt the engine up to the presant trans.
1972 Chevy c10 Cheyenne Super
Like wrenchbender says, you gotta remove the crossmember under the bellhousing, & get an auto for the rear of the automatic.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
With the correct crossmember, the 350 is a perfect fit. My 67 had a power glide that was replaced with a 350. Pretty much a bolt in. Power glide cross member worked fine.
Junior Member
Junior Member
there was a stright 6 with an automatic trans from the factory in the truck to start with so that sounds like that will help right?
