| | | Forums66 Topics128,206 Posts1,057,433 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80049 07/15/2007 8:04 PM | Joined: Jun 2006 Posts: 4 Junior Member | | Junior Member Joined: Jun 2006 Posts: 4 | I have an 52 3/4ton truck with what appears to be a 53 or later rear end. Would a 1967 Chevrolet C20 3/4 8 lug Truck Rear Axle 4.52 Ratio be any better for better speed potentials? | | |
#80050 07/15/2007 8:07 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Not really. The ratio will be the same. You'll need the '68-'72 with the 4.10 ratio to get any gains. You won't have to change the entire diff, just the 3rd member.
Bill Burmeister | | |
#80051 07/15/2007 9:37 PM | Joined: Jun 2006 Posts: 4 Junior Member | | Junior Member Joined: Jun 2006 Posts: 4 | | | |
